animated stills go bad in dvd
Russ Spencer
on Nov 18, 2009 at 9:35:24 pm
Just finished a film that includes a sequence of still photos, JPEGs, that have been animated. Look great on the timeline but when they are output as MPEG-2 and made into a DVD, they look terrible, all bit-mapped. How do I fix this?
Stephen Smith
Re: animated stills go bad in dvd
on Nov 18, 2009 at 10:09:42 pm
Are you using a broadcast monitor to see if the the photo animation looks how you want it? What settings did you use to make your mepg-2?
Stephen Smith
Utah Video Productions
Check out my Motion Tutorials
Russ Spencer
on Nov 18, 2009 at 10:12:44 pm
I don't have a broadcast monitor.
For my MPEGs, I use one past CBR at 6.9
Not all of the stills goes bad.
Stephen Smith
on Nov 18, 2009 at 10:20:28 pm
If you can afford a Broadcast Monitor it is worth it. Things look different on a computer monitor, interlacing issues is a good example.
For DVD compression I recommend a Two Pass VBR. It is possible for Compressor to struggle with compressing an image and not other.... However, I don't think that is the problem.
Is the bad images flickering when you watch it? Or are they turning into big squares?
Stephen Smith
