Automating repetitive tasks
Rob MacAulay
on Nov 17, 2009 at 3:30:02 pm
I am looking to automate a task in Final Cut Pro, such as adding 15 frames at the beginning and ending of a asset and adding intro in and intro out on an asset.
I've read where one guy has used automator to create a scrip, or macro to automate final cut pro actions sucessfully.
Can anyone give advice on how best to automate tasks in final cut pro?
Arnie Schlissel
Re: Automating repetitive tasks
on Nov 18, 2009 at 3:28:14 am
Check out Traffic from
Post production is not an afterthought!
Rob MacAulay
on Nov 18, 2009 at 9:43:37 pm
Thanks a bunch Arnie,
This looks to be an awsome utility. Looks very much like the middleware I use.
Have you used Traffic? I'm definately checking this out and the price is great, too!
Nick Meyers
on Nov 19, 2009 at 6:35:39 am
i use QuicKeys, and its pretty effective if you have a huge amount of repetitive tasks.
it's about $80-90 but there other apps that do essentially the same thing for less $$
it does take a certain amount of time to program the macros,
so it;s only really effective if you need to do the same thing a lot of times.
although what you need sounds pretty simple to program.
an important trick when programming macros is the PAUSES you leave between certain commands.
© 2018 All Rights Reserved
