Canon 7D progressive material in interlaced project
Henrik Helms
on Nov 16, 2009 at 6:49:21 pm
Is there a way to put progressive material shot on Canon 7D (1920x1080) into an interlaced project shot on JVC 700 in 1920x1080 hd.
Greetings
Henrik
Peter Wiggins
Re: Canon 7D progressive material in interlaced project
on Nov 16, 2009 at 8:34:57 pm
Yeup, run it through compressor
Peter
Henrik Helms
on Nov 16, 2009 at 8:54:47 pm
What to remember - when I run it though the compressor?
Kind regards
Henrik
Greetings
Henrik Helms
dBA MEDIA
Brian Pitt
on Nov 16, 2009 at 8:59:33 pm
Hey Peter...
you had talked about making available the compressor preset you created for converting the h.264 7D footage into something a little more work-flow friendly. Any idea when you'll do that? :)
Brian
John Davidson
on Nov 16, 2009 at 10:14:46 pm
If this helps for now, I'm using the default preset for ProRes in compressor.
Under 'settings' in compressor, it's in Apple/Formats/QuickTime/Apple ProRes. Not really sure how it deals with the interlace issue, but it's not causing me any headaches yet.
Henrik Helms
on Nov 17, 2009 at 6:22:34 am
Hi!
What the normal pro res setting in comressor does is to check the interlaced button - but I think the settings could be better than that. Any ideas on how to set the motion settings to get a better result?
Kind regards
Henrik
Greetings
Henrik Helms
dBA MEDIA
Peter Wiggins
on Nov 16, 2009 at 10:19:22 pm
Brian,
The document that goes with them is actually taking more time!
Peter
Rafael Amador
on Nov 17, 2009 at 10:05:13 am
Hi Henrik,
Just drop the footage on the time line.
Progressive footage is "universal": Works in any kind of sequence (Upper, Lower, NONE).
If you want to fake that was shoot interlaced (?) then you would need to use the Re-interlacer of the FieldsKit or so.
Rafael
http://www.nagavideo.com
