hd to sd project
geri bastian
hd to sd project
on Nov 11, 2009 at 5:21:43 pm
OK guys and gals. . . still new at this final cut pro :) Looking the best way to set up my final cut 6.
I'm editing projects- :30 commercials using P2 hd 720/30 footage and my final output will be quicktime SD file 720/480. Should i set my project up to edit in HD and then output to SD? Just want to get the best final quality i can.
Geri
Shane Ross
Re: hd to sd project
on Nov 11, 2009 at 5:57:37 pm
Edit in HD. Export a self contained QT file. Take that into Compressor and compress to the flavor of SD that you want. ProRes SD, DV50, Uncompressed SD.
Shane
