Changing entire sequence aspect ratio
Tom Hannibal
on Nov 10, 2009 at 4:51:00 pm
I'm about to play-out a sequence someone here has edited, but for some reason it has been cut into a 4x3 seqence, but the footage is all (correctly) set as 16x9. FCP has obviously letterboxed all the footage.
Is there an easy way for me to un-letterbox the entire sequence?
Cheers
Tom Hannibal
Re: Changing entire sequence aspect ratio
on Nov 10, 2009 at 5:25:26 pm
Never mind, I figured it out.
Had to duplicate the sequence, made sure the new one was 16x9, then selected everything and went Right Click > Remove Attributes and selected Distort. Job done.
