client want Mpeg2 50i converted to 25i
Max Christensen
on Nov 10, 2009 at 12:13:42 am
Great! I recived yet another dysfunctional mpeg2! ;-9 (Hate that format)
Client wants me to convert it from 50i to 25i.. That's all the info i get! I try to open it with mpeg streamclip.. Nothing. I try to open it in FCP.. wont read. I try to pull it into quicktime.. blank!
Only compresor and episode can handle it.
Now my question is.. what do i change to make 50i into 25i??
Kissis and mpeg2-huggies.
Max
Michael Gissing
Re: client want Mpeg2 50i converted to 25i
on Nov 10, 2009 at 12:20:42 am
I suspect your client doesn't use terminology correctly. 50i means 25 fps with interlaced fields. 25i means 12.5 fps with interlaced fields.
I suspect your client doesn't actually want to halve the frame rate.
Max Christensen
on Nov 10, 2009 at 12:39:40 am
Then i can only woooonder wtf he's talking about?! :p
We can both agree that 12.5 frames is impossible to look at for broadcast. I then wonder what client meens,
or wants?
Max Christensen
on Nov 10, 2009 at 12:44:19 am
Maby they meen a 50i converted to a 25p? is that likely.
Michael Gissing
on Nov 10, 2009 at 1:50:34 am
If it is an mpeg2 for broadcast it should be 50i.
I can't guess what your client wants. You will have to ask them.
