AVI file format
Larry Watts
AVI file format
on Nov 6, 2009 at 10:18:36 pm
Can the latest version of Final Cut Studio recognize and utilize an AVI file produced rendered on a PC?
thanks
Larry
Michael Gissing
Re: AVI file format
on Nov 6, 2009 at 10:44:57 pm
AVI is not a codec, just a wrapper. FCP works best when it has a quicktime wrapper so firstly the AVI needs to be converted to a quicktime and also you may need to transcode the codec to something that editis nicely in FCP.
I have in the past dropped an AVI animation codec file into an FCP timeline (final animated graphics file) and just let FCP render it as I was onlining and adding a late change before playing out to tape.
If you are editing then it would be smarter to convert to a quicktime to avoid endless rendering everytime you change an AVI clip
Jeff Gerst
Re: AVI file format
on Nov 6, 2009 at 10:52:37 pm
I work with avi files all the time - you can import them without a problem. I have found that they exhibit weird behavior sometimes, like getting out of sync, so I usually render them to a mov first, then import.
Larry Watts
Re: AVI file format
on Nov 7, 2009 at 12:04:56 am
Thanks everyone!
LARRY
