FCP 7 can't make MULTICLIP with Variable SPEED ADJUSTMENTS?
maxim tyminko
on Nov 6, 2009 at 6:26:57 pm
in FCP 7 when i try to make a multiclip from some clips with timeremapping (variable speed) i get only a dialog box saying "Unable to make Multiclip. One of the items you selected has a speed effect.".. there is only "OK" button there..
i can make a multiclip from the same clips if i remove timeremapping.. however i can't then add any speed keyframes on any active angle of this multiclip.. the speed tool hase a pointer icon with a cross and does nothing if i try to add a keyframe on the timeline.. in the motion tab of the viewer the round "keyframe" button for speed is also disabled..
This all was possible in FCP 6. and in the user manual for FCP 7 stays also that "Individual angles can have filters, motion settings, and speed adjustments applied."
am i missing something? maybe somebody knows how to solve this problem? will really appreciate any suggestions..
