Timecode Cuts?
Orrin Hogan
Timecode Cuts?
on Nov 6, 2009 at 5:16:42 pm
Is there a way to make cuts by just typing in time you need cut? I have a log sheet to go by and rather then having to use razor every time I need to make a cut is there a faster method? I know "B" is the shortcut for the razor tool I was just wondering if it's possible to do it just by typing in the numbers and have the cuts automatically happen as you do it.
Thanks in advance!
Jeremy Garchow
Re: Timecode Cuts?
on Nov 6, 2009 at 5:56:04 pm
type in tc, then hit control-v
Jeremy
