Track-Based Audio Editing?
Collin Alexander
on Nov 5, 2009 at 6:20:37 pm
FCP audio editing is object-based. Changes are applied to individual clips on the timeline.
Isn't there some way to work with an entire track? Say, for example, I wanted to turn the volume down on a track, that is every clip that is on that track. The audio mixer only seems to edit each clip individually. Isn't there a way to apply a filter to a track, instead of to a clip?
Or, if there's no way to do track-based editing, is there any way to edit multiple audio clips simultaneously?
Thanks for any help.
Joey Burnham
Re: Track-Based Audio Editing?
on Nov 5, 2009 at 6:56:38 pm
I don't think so but I could be wrong.
Workaround would be to export a .aifs of the sequence, duplicate your sequence to retain your edits as a backup, and cut in the .aif on the track you want in the new sequence.
Joey
cowcowcowcowcow
Shane Ross
on Nov 5, 2009 at 7:03:56 pm
Sure can...have I got a TRICK for you!
Press the letter "T" three times to turn your mouse into an arrow that points to the left and right. Click on the track you want to adjust the audio on. (NOTE: If you have Stereo Pairs, BOTH pairs will be affected!) Now press the CONTROL KEY and then the [ or ] key (brackets) to adjust audio up and down 3db ([ for +3db, ] for -3db), or CONTROL and - or + for 1db increments.
Cool?
Shane
Joey Burnham
on Nov 5, 2009 at 7:05:55 pm
I KNEW there was a way! My coworker had to do this years ago and I couldn't remember his solution.
Kudos
Jeremy Garchow
on Nov 5, 2009 at 7:44:05 pm
Well, after reading all of the posts, you can next the audio too. That will turn your audio in to one big audio track with which you can add filters and what not.
Shane Ross
on Nov 5, 2009 at 9:24:02 pm
[Jeremy Garchow] "you can next the audio too."
He meant to say "NEST" the audio...
Shane
Jeremy Garchow
on Nov 5, 2009 at 9:52:08 pm
[Shane Ross] "He meant to say "NEST""
Yes, I did. Thanks for that.
Arnie Schlissel
on Nov 6, 2009 at 4:18:17 pm
If you send your sequence to Soundtrack it will behave in exactly the way that you want. STP is a dedicated audio mixing & editing tool, and it's volume envelopes are attached to the track, not to the clip.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Collin Alexander
on Nov 8, 2009 at 4:39:37 pm
Thank you, thank you. Yes, great solutions. Maximum appreciation.
Christina Knickerbocker
on Oct 21, 2011 at 9:36:05 pm
You guys just saved me a lot of work, thanks!
