59.94 clips into 29.97 seq
Chris Monico
on Nov 5, 2009 at 5:47:10 pm
Anyone try pasting the clips from a 59.94 sequence into a 29.97 sequence in Final Cut 7.0.1? Doesn't seem to work for us, and It worked fine in previous versions. This would be a big problem for us when conforming a show from multiple sequences/projects.
Jeremy Garchow
Re: 59.94 clips into 29.97 seq
on Nov 5, 2009 at 6:12:23 pm
720P to SD?
1080p60 to 720p30?
Please give formats.
Chris Monico
on Nov 5, 2009 at 6:17:27 pm
Sorry, All Apple Pro res HQ 720p 59.94 clips in a 59.94 seq pasted into apple pro res 720p seq @29.97.
Jeremy Garchow
on Nov 5, 2009 at 6:22:46 pm
And why are you doing this?
Chris Monico
on Nov 5, 2009 at 7:00:12 pm
multiple editors on 1 project created sequences at 59.94 and 29.97. need to create one unified sequence at 29.97. Any HELP would be appreciated.
Jeremy Garchow
on Nov 5, 2009 at 7:13:53 pm
[Chris Monico] "need to create one unified sequence at 29.97. Any HELP would be appreciated."
I'd go the other way. Copy the 29.97 and paste in to a 59.94.
Jeremy
Chris Monico
on Nov 5, 2009 at 7:36:12 pm
Never thought of that.
But why can't I do the reverse?
Jeremy Garchow
on Nov 5, 2009 at 7:41:50 pm
Because 720p is 59.94. If you copy an edited sequence from 59.94 to 29.97, you are throwing away half of the frames and will produce inaccurate motion. If you copy and paste a 30p sequence in to a 59.94 sequence, you will simply get 30p playback with properly rendered in pulldown.
It will look better is the easy answer.
Jeremy
