Multiple Background/Share Renders
Jeff Gerst
on Oct 31, 2009 at 12:34:27 am
Is there a way to send more than 1 sequence to "share" to background render while you keep working?
Or any other way to render multiple sequences & keep working?
Thx.
Shane Ross
Re: Multiple Background/Share Renders
on Oct 31, 2009 at 1:57:48 am
[Jeff Gerst] "Is there a way to send more than 1 sequence to "share" to background render while you keep working? "
Render? Or output compress? FCP 7 can SHARE to compress on output to a QT file in the background. But you cannot use SHARE to render a sequence.
[Jeff Gerst] "Or any other way to render multiple sequences & keep working? "
YOu cannot render and continue to edit. FCP does not do that.
Shane
Jeff Gerst
on Oct 31, 2009 at 2:43:41 am
Thx for response -
I basically want to make a qt mov of more than 1 file at a time and keep working. Right now, I can use "share" & start the qt creation and keep working. I'd like to do that multiple times & keep working.
