WMV Exports, Audio Issue
Greg Smith
on Oct 29, 2009 at 7:25:04 pm
Hi all,
I am having an issue exporting windows media files from FCP and Compressor. This is something that I do on a regular basis with no problems.
To start, I am using the latest Flip4Mac (Studio Pro HD).
My timeline layout is as follows:
3 sec Black, 30 Bars & Tone, 10 Slate and then the 30 spot.
After I select my I & O (30 spot) I go through the normal export with QT conversion and adjust the settings accordingly (in this case a preset). However when the compression is complete the file size is larger than normal and the audio starts from the beginning of the timeline. So I hear the 3 black then 27 of tone. Very Strange! This is only happening with Windows Media Files. QTs export fine.
Anyone else had this issue?
Greg Smith
Phil Balsdon
Re: WMV Exports, Audio Issue
on Oct 29, 2009 at 9:04:28 pm
There are issues with audio sync and Flip4Mac. Apparently only in Quicktime replay on a Mac though.
http://forum.telestream.net/forum/messageview.aspx?catid=9&threadid=2405&hi...
Try exporting the sequence as a self contained Quicktime movie and then using Compressor to convert that version. I've had a similar problem to yours at the end of a sequence when going to Compressor direct from FCP which was resolved this way.
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://www.steadi-onfilms.com.au/
Greg Smith
on Oct 29, 2009 at 10:51:55 pm
Phil,
Thanks, I did discover that work around. It is just strange that I had not had this problem at all in the past. I have exported hundreds of .wmvs directly from FCP and Compressor with no issues. Today it seems as if it just decided to stop working. Hopefully when I get to the office tomorrow, it will have resolved itself.
I did try un-installing and re-installing flip4mac, trashing the FCP prefs, and rebooting.
Greg Smith
on Oct 30, 2009 at 3:14:02 pm
This is an issue with the latest version of Flip4Mac.
http://forum.telestream.net/forum/messageview.aspx?catid=10&threadid=3772&e...
I reverted to an earlier version and am now working again.
Phil Balsdon
on Nov 6, 2009 at 5:36:02 am
An update on this.
You can download a Mac compatible version of Windows Media Player here;
http://www.microsoft.com/windows/windowsmedia/player/mac/mp9/default.aspx
Using this for replaying wmv files created in Flip4Mac resolves the audio sync glitch that occurs in Quicktime replays.
