motion master templates on FCP 7.01
Gabriele Girardi
on Oct 28, 2009 at 12:57:22 pm
hallo everybody,
on FCP 7.0.1 when i select master templates in the viewer (any kind, hd sd ecc)
it seems load it but after a few seconds i see a white screen no images, nothing..
anyone knows what is the problem?
Tom Wolsky
Re: motion master templates on FCP 7.01
on Oct 28, 2009 at 2:03:05 pm
Works for me. Are the templates in the standard location? Is the viewer set to RGB or alpha?
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP6," "Basic Training for FCS2" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Gabriele Girardi
on Oct 28, 2009 at 4:34:18 pm
viewer is in RGB
where is the correct location?
Gabriele Girardi
FCP_Editor
Tom Wolsky
on Oct 28, 2009 at 5:11:59 pm
The default location is Hard Drive/Library/Application Support/Final Cut Studio/Motion
All the best,
Tom
Gabriele Girardi
on Oct 28, 2009 at 5:32:30 pm
thanks a lot for you help,
but i does not work...
it seems to load the template 'cos i can work on the controls of template
but it gives me only the white screen.
another think i notice is that when i was working with FCP 6 it was not a problem
and i could even open the .motn files with Quicktime!!
now i can't?
how do you explane that?
when i try to open motn files it gives me error, i think it's abug of quicktime X
talk soon
thank you
Gabriele Girardi
FCP_Editor
Tom Wolsky
on Oct 28, 2009 at 5:37:16 pm
What OS and QuickTime versions are you using?
All the best,
Tom
Gabriele Girardi
on Oct 28, 2009 at 5:45:57 pm
OS X Snow Leopard (10.6.1)
Quicktime 10.0 (51)
thanks
Gabriele Girardi
FCP_Editor
Tom Wolsky
on Oct 28, 2009 at 6:02:59 pm
Did you do a clean erase and install of the OS?
Try opening the templates in the QuickTime 7 player, not the QT X player.
All the best,
Tom
Gabriele Girardi
on Oct 28, 2009 at 6:13:27 pm
i just did an upgrade. did not erase anything
i just opened a motn file zith quicktime 7..!!!
i have to do i clen installation of snow leopard?
thank you
Gabriele Girardi
FCP_Editor
Tom Wolsky
on Oct 28, 2009 at 6:27:54 pm
New operating systems need a clean erase and installation and full reinstall of the software. You should not update to a new operating system with the pro apps.
All the best,
Tom
David Chai
on Oct 29, 2009 at 5:00:41 am
I've seen this problem on a friends Quad Core macpro. 10.5.8, QT 7.6.4, FCP 7.01. Template opens fine in Motion but is always a white screen in FCP. Video is fine, only Motion Templates are a probIem. I suspect its to do with either not enough memory, only has 3GB, or the graphics card, ATI 2600 in this quad core machine. 8 core machines don't seem to have any issue. Another quad core with 1900XT is also ok, but it also has 11GB of RAM.
David Chai
Director . Camera . Editor
http://www.davidchai.com
dc@davidchai.com
212 363 0159
Mark Palmos
All Moton Templates showing up as WHITE?!
on Nov 4, 2009 at 11:19:51 pm
Oh my god...
I have the same problem.
White templates, regardless of whether they are templates that came with FCP or templates I just made...
I installed Snow Leopard on a clean hard drive three days ago, and FCP Studio, of course also a clean install, updated, have all my KONA LHE drivers etc... viewer set to RGB/Image...
Any ideas?
Thanks guys,
Mark.
Mark Palmos
on Nov 4, 2009 at 11:40:42 pm
Gabriele, I found this using Google's search (the cow did not find this for some reason)
http://forums.creativecow.net/thread/8/1046031
Basically you need to remove
MBCC.fxplug
MBCC_Slider.fxplug
from your plugins folder.
Mark
