• | Fuzzy tites
on Oct 27, 2009 at 11:09:01 pm |
I edited a PAL Sequence with 14 video channels of titles (each layer is one word in size 18). i used the "text" function in the program. it looks great on the Canvas but when i exported it as "current settings" the letters became fuzzy
Does anyone knows what's the deal?
Thanks in advance
• | Re: Fuzzy tites on Oct 27, 2009 at 11:38:34 pm |
Strike 1. Using FCP's Text. Use Title 3D, Live Type or Motion for text.
Strike 2. 18 is very small font size for video.
Strike 3. You need to view the final rendered output on a PAL monitor.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
• | Re: Fuzzy tites on Oct 28, 2009 at 12:47:31 am |
Thanx for quick and helpful unswer
• | Re: Fuzzy tites on Oct 28, 2009 at 1:33:38 am |
Steve left out one very important thing. Don't use DV compression. Go to Sequence>>Settings and change the compressor to DV50 or Pro Res.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
• | Re: Fuzzy tites on Oct 28, 2009 at 5:42:23 pm |
Thanks a lot, I'll deferentially try that. will it have any affect when burning to DVD?
• | Re: Fuzzy tites on Oct 28, 2009 at 6:33:51 pm |
Same thing... It will make you titles and graphics better because DV compression erodes the heck out of them, so if you can avoid the issue before compressing to MPEG2 for your DVD you're way ahead of the game.
Read my post below for an explanation of the issues with DV compression.
http://forums.creativecow.net/readpost/8/1011833
David Roth Weiss
Director/Editor
Los Angeles
• | Re: Fuzzy tites on Oct 29, 2009 at 12:50:03 am |
Thanks David. i used the Pro-res compression as you recommended. The titles and the image look much better now. only thing is, in some parts- the video became interlaced. (mainly during movement...). should i use the "De-interlace" filter for those parts? from past experience using the filter harms the sharpness.
• | Re: Fuzzy tites on Oct 29, 2009 at 3:36:44 pm |
No, do not deinterlace. If you are only using titles and graphics try again going into Sequence>>Settings and change Field Dominance to "none."
David Roth Weiss
Director/Editor
Los Angeles
• | Re: Fuzzy tites on Oct 30, 2009 at 5:32:08 pm |
major difference ! Thanks
• | Re: Fuzzy tites on Oct 30, 2009 at 7:56:33 pm |
[Gilad Ratman] "major difference ! Thanks"
YVW! Always good to hear success stories...
So, you now have a reliable workflow. Remember what you did and write it down for future reference. And of course, you can always refer to this thread, which will be archived forever here on the Cow.
David Roth Weiss
Director/Editor
Los Angeles
