Export Crash
Emilio Martinez
Export Crash
on Oct 27, 2009 at 5:10:32 pm
Everytime I select Export/Using QuickTime conversion or Batch Export/Settings, FCP completely shuts down. I have trashed my preferences and uninstalled some FX plugs that were not loading. I have tested out projects and sequences that previously worked with these commands to no avail. I recently used the XSlimmer demo to slim down Final Cut, but I have since restored the backup version.
FYI, I am still able to export via the regular "QuickTime Movie" command.
Any ideas? Thanks!
John Fishback
Re: Export Crash
on Oct 27, 2009 at 7:37:56 pm
Did you repair permissions? Also, run Disk Warrior.
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
© 2018 All Rights Reserved
