mpeg-4 import
gi thomson
mpeg-4 import
on Oct 26, 2009 at 8:05:43 am
Hi gang,
i'm trying to import some files that are in the MPEG-4 format. They're in a BPAV folder, and each folder has a few files with suffixes:
I've tried to open the MP4 in mpegstreamclip, but it doesn't recognise it. I've tried to import the folders into fcp using log and transfer, but it doesn't recognise them either. I need to finish this job tonight, so any help would be muchly appreciated.
Rafael Amador
Re: mpeg-4 import
on Oct 26, 2009 at 12:50:40 pm
Hi gi,
Don't mess in the BPAV folder if you want to reduce headaches.
Put the BPAV folders each inside another folder.
Run SONY Transfer Tool and "Add" those folders.
Select and Import.
Files will download as QT (.mov) ready to edit.
Those MP4 are not Mac playable. You will need a third part plugin.
© 2018 All Rights Reserved
