FPV to tape?
Phil Giriodi
FPV to tape?
on Oct 25, 2009 at 7:05:18 pm
My system is: Mac Intel, Max RAM, many HDs, OS 10.5.6, FCP 5.1.4
I am able to capture HDV into FCP, however, when I attempt to 'print-to-tape' my deck will not capture. My HDV deck is a Sony 1080i, HVR M-1OU.
Print-to-tape works fine in the SD mode but not the HDV. I've tried every setup combination that I can think of.
Your assistance would be greatly appreciated.
Thanks in advance.
Michael Gissing
Re: FPV to tape?
on Oct 25, 2009 at 9:15:17 pm
Vers 5.1.4 was early days for HDV in Final Cut. I am not sure if later version can print HDV to tape either but I am pretty sure it doesn't work in that vers.
You could try searching the forum as it has come up many times before.
Phil Giriodi
Re: FPV to tape?
on Oct 25, 2009 at 9:41:36 pm
Thanks Michael. I will upgrade next week once present project is completed.
However, the print-to-tape window and footage is displayed on my computer monitor, it just won't bump over to tape. (???)
Michael Gissing
Re: FPV to tape?
on Oct 25, 2009 at 11:05:14 pm
Do a search of this forum. It may not be possible to print to tape in HDV. I just don't know so you will have to do a bit of research.
Zane Barker
Re: FPV to tape?
on Oct 26, 2009 at 3:07:20 am
I believe that it is edit to tape that is not possible with HDV.
When printing to tape HDV must conform, and that will take a LONG time.
There are no "technical solutions" to your "artistic problems".
Don't let technology get in the way of your creativity!
Jerry Alto
Re: FPV to tape?
on Oct 29, 2009 at 9:47:13 pm
Phil- You should be able to print to tape. Go to Audio/Video Settings A/V Devices. Make sure the box 'Different Output for Edit/Print to Tape' is NOT checked. When it starts the conforming process (HDV) you'll know you are good to go.
HTH,
Jerry
G5 Dual 3GB Ram
FCP Studio 6.02
External 1 TB SATA Raid 0
Kona LH, Second system w AJA ioLA
Sony Z-1
GV-HD700
