Color correction and external monitor
francisco bech Gómez
on Oct 25, 2009 at 12:00:02 pm
Hello again, I want to correct colors with FC and external broadcast monitor. It is better to use an analog monitor or a Digital monitor. Apple sells a Mini DVI to Video adaptor with composite (RCA) and SVideo outputs, would this be enought to work with an analog monitor? or I need a canopus card to use conponent video, is this an important issue for the image in the monitor?
Thanks very much for your help
walter biscardi
Re: Color correction and external monitor
on Oct 25, 2009 at 12:18:36 pm
Analog or digital are fine so long as you have a properly calibrated monitor and feeding it a good, professional signal.
[francisco bech Gómez] "Apple sells a Mini DVI to Video adaptor with composite (RCA) and SVideo outputs, would this be enought to work with an analog monitor? "
Composite is the worst possible choice for monitoring professional video. S-Video is the bare minimum so long as you have a properly calibrated external monitor.
If you're working in HD, then Component is the bare minimum you will require.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media
"Foul Water, Fiery Serpent" now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
Blog!
Twitter!
on Oct 25, 2009 at 6:35:17 pm
Hello, thanks very much for your help
I am working in DVCpro 50 in Imac. Could you tell me please how can I get the signal to a monitor? I guess the only output is the Mini DVI . I been researching and I cant find a clear answer for this
It would be digital or analog?
Best regards
Michael Gissing
on Oct 25, 2009 at 9:02:20 pm
Look at the AJA IO .
