Media Manager and Multiclips
Kevin Monahan
on Oct 24, 2009 at 5:01:00 pm
Could not trim media at all with the Media Manager and using multiclips. I have tried collapsing multiclips prior to media managing, but that didn't help. Source is ProRes HQ 24.0 fps. There may be some XDCAM clips in there, and they are often a different frame rate.
Any ideas guys?
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Shane Ross
Re: Media Manager and Multiclips
on Oct 24, 2009 at 5:27:26 pm
If I used Multiclips or Merged clips, I might, but I don't...so..sorry.
I media manage all the time...but not with that stuff.
Shane
John Pale
on Oct 24, 2009 at 8:14:53 pm
Media Manager cannot trim anything without a reel name.
Do the XDCAM clips have anything in the reel name column?
Nick Meyers
on Oct 25, 2009 at 1:01:46 am
Hi, Kevin.
it should work.
as john mentions, you need a reel# on all clips.
one more thing to try would be a two-stage media manage.
when you "Collapse" a multiclip, the clip actually remains a multiclip, just collapsed (it can be UN collapsed)
in XMLs, the clip is still flagged as a multiclip,
so im guessing a collapsed multi would survive media management, and still be able to be un-collapsed.
however, in the Media Manager there is a check box to include other multiclip angles or not.
try that and see if it helps.
otherwise a 2-step plan would be to:
COPY
DONT DELETE UNUSED
DONT INCLUDE MULTICLIP ANGLES
and then:
COPY
DELETE UNUSED
all the best,
nick
