ProRes 4444 not available in Log & Transfer with R3D?
Brendan Coots
on Oct 24, 2009 at 5:26:33 am
I am conducting some tests using RED footage, FCS3 and CS4 Suite to get a handle on best practices for post. The files are in a folder on my local drive so I'm NOT capturing directly from camera.
It seems that a lot of people are suggesting the use of REDRushes for capturing R3D to ProRes 4x4, but I wanted to run it through FCP 7's Log & Transfer for testing. I am only getting ProRes422 or HQ as my RED capture options, no 4x4. In another thread it was mentioned that you need a capture card to do this? Is this true even with local footage, NOT from the camera directly? Did I misinterpret that post altogether?
Thanks in advance
Brendan Coots
Splitvision Digital
http://www.splitvisiondigital.com
gary adcock
Re: ProRes 4444 not available in Log & Transfer with R3D?
on Oct 26, 2009 at 1:06:51 pm
[Brendan Coots] "It seems that a lot of people are suggesting the use of REDRushes for capturing R3D to ProRes 4x4, but I wanted to run it through FCP 7's Log & Transfer for testing. I am only getting ProRes422 or HQ as my RED "
without a capture card the 4444 setting for ProRes were not installed by default.
if you go to Applications > Final Cut Pro Additional Easy Setups you will find all of the additional easy setups including the ones for the 4444 codec.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
