What is the highest version of Quicktime and iTunes I should use with FCP 5?
Ian Dillon
on Oct 23, 2009 at 1:44:03 am
What is the highest version of Quicktime and iTunes I should use with FCP 5? I know if I go to high on either I will run into problems. What are the magic numbers? Someone mentioned checking version tracker, but I don't think it gives that type of info. Somewhere there must be a post about this.
HELP!
Playroom Creative
http://www.playroomcreative.com
Rafael Amador
Re: What is the highest version of Quicktime and iTunes I should use with FCP 5?
on Oct 23, 2009 at 2:03:08 am
[Ian Dillon] "Someone mentioned checking version tracker, but I don't think it gives that type of info. Somewhere there must be a post about this."
Yes. This information is available.
Look for it and try to learn from the original source.
In a post you hardly will find the same info.
rafael
http://www.nagavideo.com
