Best quality when exporting to DVD
Tasmin Fletcher
on Oct 21, 2009 at 11:42:25 am
What is the best/optimal format to use for exporting to both DVD and Beta (captured in 8-bit uncompressed)?
Rafael Amador
Re: Best quality when exporting to DVD
on Oct 21, 2009 at 1:23:00 pm
Whenever you export, the less compression you apply, the best quality you should be able to achieve, or at least, the less you will degrade your picture.
If you are making a movie that later you want to distribute in different formats, export a good master. Prores may be the best option.
Rafael
http://www.nagavideo.com
Tasmin Fletcher
on Oct 21, 2009 at 1:39:29 pm
Thanks Raphael, I am going to try out the Prores options.
