Outputting a XDCAM Seq to an SD Letterbox Quicktime
Jeffrey Lonigro
on Oct 20, 2009 at 4:39:49 pm
I tried nesting my XDCAM sequence into a 720x486 ProRes(HQ) sequence and this did the leterboxing great but the image looks pretty bad. I tried exporting out an XDCAM self contained movie and importing that into the SD sequence with the sam results.
I am trying to figure the settings in Compressor to achieve the same letterboxed 720x486 results but can not get it to letterbox and maintain the proper aspect. Everything just looks squished.
Rafael Amador
Re: Outputting a XDCAM Seq to an SD Letterbox Quicktime
on Oct 21, 2009 at 5:08:17 am
[Jeffrey Lonigro] "I tried nesting my XDCAM sequence into a 720x486 ProRes(HQ) sequence and this did the leterboxing great but the image looks pretty bad. "
Set "render all YUV material in High Precision" and "Render Motion Effects: BEST".
This should helps with the downscaling.
rafael
http://www.nagavideo.com
