Color Space
Jimmy Stewart
Color Space
on Oct 19, 2009 at 9:05:51 pm
Im using compressor to make mpeg2 files for dvd. original material is xdcam that im downconverting. works fine when i bring into dvd studio pro. thing is, the white are blown out. i want to change the color space in compressor, but it is grayed out and wont let me change it from "default for encoder"
anyway thoughts on how to change this?
thanks,
j
John Fishback
Re: Color Space
on Oct 19, 2009 at 9:16:52 pm
What about using Brightness And Contrast in the Filters tab?
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Michael Gissing
Re: Color Space
on Oct 19, 2009 at 9:17:20 pm
Did you grade the XDCam footage? If you are clipping peak whites over 100% by making an mpeg, changing color space won't help.
