audio during digitize
Tom Dempsey
on Oct 16, 2009 at 7:42:48 pm
Is it possible to monitor all 4 channels of audio during a digitize. I'm digitizing HD ProRes422
onto FCP7 with AJA Kona 3 card. Running OSX 10.5.6 on a 2x2.26 Ghz Quad Core system.
Audio is monitored thru a Mackie 1202-VLZ audio board. I'm getting all 4 channels, but would like to hear them during the digitize. only hear 1 and 2.
thanks,
tom
Michael Gissing
Re: audio during digitize
on Oct 16, 2009 at 11:33:11 pm
You need to select 4 channel audio outputs in the settings of the sequence you are capturing into. Set to 4 audio outputs, otherwise you will monitor the default 2 channel.
