multi-format woes
Kurt Uebersax
multi-format woes
on Oct 16, 2009 at 2:47:22 am
I have a unique project, looking for some help- I have "behind the scenes" footage from a conference shot in SD 4:3 on a Sony PD170. Simple enough, until the client gave me 2 hard disks of HD 16:9 images also used during the conference from a separate video setup (the Image Mag/Closed Circuit Feed), and they want me to mix the images. So far my plan seems to be set up my sequence for the SD 4:3 (lowest of the qualities), and render in the HD 16:9 clips as needed. 3 questions:
1. Am I on the right track?
2. When exporting (DVD is end deliverable), is there a way to "conform" the entire piece to either 4:3 or 16:9? Ideally, I would love to give them a DVD of each if possible, and they can choose which they like.
3. Suggestions on what compression (if any) I should use?
I'm newer to using my FCP, Have 7.0.
Best,
Kurt Uebersax
http://www.kjuproductions.com
Rafael Amador
Re: multi-format woes
on Oct 16, 2009 at 5:37:56 pm
Hi Kurt,
That's the way.
Work in a DV 4x3 sequence and resize the HD shoots as needed.
You may get a better result if before rendering you set your sequence codec to DVCPro50 or better.
[Kurt Uebersax] "2. When exporting (DVD is end deliverable), is there a way to "conform" the entire piece to either 4:3 or 16:9? Ideally, I would love to give them a DVD of each if possible, and they can choose which they like. "
once you have imported the MPEG-2 to DVDSTP, you need to check the clips as 4x3.
[Kurt Uebersax] "3. Suggestions on what compression (if any) I should use? "
The Compressor Presets are OK to start.
rafael
http://www.nagavideo.com
Kurt Uebersax
on Oct 16, 2009 at 8:29:39 pm
Thanks Rafael, seems to be working!
Best,
Kurt Uebersax
