ingest growing files from Sony disk recorder
Frank Steffenhagen
on Oct 15, 2009 at 2:35:35 pm
Hi everyone,
I wonder if anybody has done any ingesting of growing files
from a Sony disk recorder (DSR-DR1000AP). This could either be
via re-wrapping the file or accessing the disk recorders
hardware from within FCP.
Important is that the file has not got a fixed file size with
an in/out, it's a live recorded track that grows over time
and should be accessed as such within FCP. The problem I have
is that we use FileZilla (connected via Ethernet) which gets
the file into the computer. From there you can import the file
in FCP, once you load it into the player window it stops updating
A theory could be that this is a DV stream, which does not have
a header that tells the software to keep the file growing over
My question: is there any re-wrapping software that can deal with
growing file sizes? I heard about MovieRecorder from Softron and
Quick Time reference files and was wondering, if anybody has dealt
with it.
Thanks for your time. Cheers
© 2018 All Rights Reserved
