FCP export of MXF for Pro Tools
Tino Zidore
on Oct 15, 2009 at 11:33:51 am
Hello!
I'm trying to export a sequence from Final Cut 7 to Pro Tools, as an MXF.
- I use Export - Sony XDCAM in the "File" menu, and it works fine, I get the MXF file I want.
Trouble starts when I try to open it in Pro Tools, a pop-up with the following message appears:
"The selected video clip's compression level is incompatible."
Does anyone know a workaround for this problem?
Kind regards'
Tzidore
Rafael Amador
Re: FCP export of MXF for Pro Tools
on Oct 15, 2009 at 12:46:17 pm
Hi Tino,
I have no much experience with MFX files, but I have been having a look to the MFX options of exporting from FC via Export to XDCAM.
I guess that Protools can not cope with the codec, size or data rate of your clip.
I find out that MFX supports DV.
Just drop your movie in a DV sequence and Export to XDCAM MFX.
You need to have 4 channels audio.
Best,
rafael
http://www.nagavideo.com
Tino Zidore
on Oct 15, 2009 at 12:54:29 pm
Hi Rafael
I have already tried that and I'm sorry to say it doesn't work.
Have you got it to work in Pro Tools with these export settings you mention?
/tzidore
Rafael Amador
on Oct 15, 2009 at 1:22:53 pm
[Tino Zidore] "Have you got it to work in Pro Tools with these export settings you mention?
No.
My only experience with MFX is to give EX-1 QT files to my PC mates.
No idea if this may be a problem with the MFX files or a problem with Protools.
Check if the MFX you have exported can be open with a video application (PP, AVID,..) or with VideoLan.
rafael
Jeremy Garchow
on Oct 15, 2009 at 6:21:45 pm
Why MXF? Don't you mean OMF?
Rafael Amador
on Oct 16, 2009 at 11:41:17 am
Tino Zidore
on Oct 16, 2009 at 11:46:34 am
It is a MXF I need. It's for the sound department, and I have already made a AAF for them, but they are asking for a MXF aswell.
Jeremy Garchow
on Oct 19, 2009 at 7:09:08 pm
[Tino Zidore] "It is a MXF I need. It's for the sound department, and I have already made a AAF for them, but they are asking for a MXF aswell."
You need to find out exactly what they need as MXF is just a container. It's like saying, "Give me a Quicktime Movie". It could mean anything. I highly doubt they want an XDCam MXF file.
Jeremy
