FCP crashing when adding a clip to timeline.
Olivier Aubut
on Oct 14, 2009 at 1:33:40 pm
Hi guys
I've been having crashing issues for quite some time now. FCP keeps crashing, at least once a day. It seems to happen when I drag a clip from the viewer to the timeline.
I'm working exclusively with multiclips on this project so I don't know if the crashing still occurs on normal clips.
It happens randomly, but always when I'm dragging a clip to the timeline and I can't reproduce the crash, so I'm ruling out the "bad clip" possibility. I've tried trashing my prefs.
I'm running FCP 6.0.6
OSX 10.5.8 on an octo 3.2 GHz with 8 GB of RAM, Kona LH
Dvcpro HD on a G-Speed XL connected through Fiber Channel.
Here's a link to the crash report: 327_fcpcrashreport.rtf.zip
Any help is much appreciated. I'm starting to show signs of carpal tunnel syndrome hitting command-s every 30 seconds. ;)
Olivier
Tom Wolsky
Re: FCP crashing when adding a clip to timeline.
on Oct 14, 2009 at 3:20:36 pm
What OS is this? What version of QuickTime?
It could be a hardware issue.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP6," "Basic Training for FCS2" and "Final Cut Express Made Easy"
Author: "Final Cut Pro 5 Editing Essentials" and "Final Cut Express 4 Editing Workshop"
Olivier Aubut
on Oct 14, 2009 at 3:32:33 pm
Thanks Tom
Quicktime is version 7.6.4 and Kona LHe driver version is 6.0.2.
Olivier
Tom Wolsky
on Oct 14, 2009 at 4:10:21 pm
The OS, the operating system?
All the best,
Tom
Olivier Aubut
on Oct 14, 2009 at 4:14:55 pm
10.5.8, Leopard.
Tom Wolsky
on Oct 14, 2009 at 4:43:51 pm
You might want to contact AJA, but I think it may be a hardware problem on the computer, RAM or processor.
All the best,
Tom
Olivier Aubut
on Oct 14, 2009 at 4:51:21 pm
Thank you Tom
I'll try to uprade to the latest Kona driver, and if that doesn't help I'll contact AJA.
Olivier
steve knattress
on Oct 14, 2009 at 4:44:14 pm
How big is your project?
I did some multicam work (9 xdcam dvcam) when my project size got larger ( more than 100Mb) I experienced many crashes.
Try and trim your project and see if the crashes still happen?
I found that just doing a "save-as" and deleting sequences etc. does not work.
You need to make a new project and transfer sequences etc into it.
Steve
Olivier Aubut
on Oct 14, 2009 at 4:58:43 pm
Thanks for your help Steve.
This particular project is only 13 MB, but I've had problems before with projects bigger than 100MB as well.
I should start a new thread for this but have you had the chance to work with multiclips on FCP7? Is it more stable?
Olivier
