How many hours have i worked on this?
Ala Taha
on Oct 13, 2009 at 1:54:02 am
Does anyone know if there is a way to see how long i have worked on a final cut project? I know it's a long shot but it would be nice if there is. Thanks in advance.
Rebecca Gillaspie
Re: How many hours have i worked on this?
on Oct 13, 2009 at 4:16:51 am
Go to your autosave vault.
"Imagination is more important than knowledge." Albert Einstein
Rebecca Gillaspie
Producer, Editor
rgillaspie@gmail.com
Ben Holmes
on Oct 13, 2009 at 3:46:54 pm
The autosave vault is usually set up to keep a maximum number of saves, so it will likely have deleted the older saves. Nice idea though - I'm guessing the OP has been working on this for a while...
As far as I know, it's the only possible way of checking this - perhaps if you use Time Machine to back up project files?
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer
http://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
Ala Taha
on Oct 13, 2009 at 5:48:01 pm
Actually it hasn't been that long so i think all the saves are there. The autosave vault didn't give me the exact number but it helps give me an idea. Thanks to both of you.
christopher Griffin
on Oct 13, 2009 at 7:12:46 pm
I usually keep a pad of paper on my desk and annotate my hours worked. Little notes like "930-1100 - Capture". Doing so helped me realize I was editing rather quickly but I got sidetracked a lot. After removing my distractions, I cut my work time nearly in half. May not help those who get paid hourly, but definitely helps you if its $/project.
Mark Suszko
on Oct 13, 2009 at 8:04:41 pm
You might use the built-in sticky notes app to sign in and sign out every day.
"Oh, you wanted to RECORD that?"
Anthony Dalesandro
on Oct 14, 2009 at 11:25:25 pm
I use Google calendar to track my hours for each project. That way I can access my hours from home to do the invoicing.
Anthony Dalesandro
anthony@anthonydalesandro.com
http://www.anthonydalesandro.com
