My lower-third is pixilated after export
Jafar Fallahi
on Oct 10, 2009 at 3:55:45 pm
Hey all,
I'm pretty new to FCP and am trying to apply a lower third graphic from AE in FCP, but when I export and view it in Quicktime, the graphic gets pixilated and the doesn't look half as good as it does in the FCP viewer.
I'm exporting in 3:4 format and am wondering if the low resolution is having something to do with it. When I tried to export it in a larger HD format, the graphic looked okay, but of course the video was stretched.
Any advice?
Thanks so much!
Kevin Monahan
Re: My lower-third is pixilated after export
on Oct 10, 2009 at 4:01:13 pm
Tell us more about your precise frame size, codec, workflow.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author - Motion Graphics and Effects in Final Cut Pro
Jafar Fallahi
on Oct 10, 2009 at 4:30:27 pm
The movie is an mp4, 640x480. I'm exporting from AE in the same format, 640x480 as a quicktime animation which I import into FCP with an alpha layer. The intro and extro animation that I did, with the same format but now alpha, worked fine and are as crisp as can be...
Jafar Fallahi
on Oct 11, 2009 at 6:25:47 pm
any advice?
Joey Burnham
on Oct 12, 2009 at 5:31:44 pm
mp4 could likely be your problem. Try transcoding to another format (animation maybe?).
