truble with 25 ftg material in a 24ftg project ;)
Laura Rossi
on Oct 7, 2009 at 3:22:30 pm
Hi to everyone and thank you in advance.
I have the follow problem:
I'm working in fcp on a 24ftg project but I've some 25ftg material.
is there any way to put this material on the timeline without any problem?
Thank you
Laura.
Dave LaRonde
Re: truble with 25 ftg material in a 24ftg project ;)
on Oct 7, 2009 at 4:30:43 pm
Make a copy of the 25 fps footage. Drag the copy into Compressor. Use Compressor to convert the frame rate to 23.98 (also called 23.976), to the codec being used by the rest of your footage, and to the horizontal and vertical resolution of the rest of your footage.
Dave LaRonde
Sr. Promotion Producer
Laura Rossi
on Oct 7, 2009 at 4:44:44 pm
Thank you Dave!
I'll try right now.
I've seen also the conform 25 to 24 on the tools menu, but I've never used it, could it be another possibility?
thank you again Dave.
Laura
Dave LaRonde
on Oct 7, 2009 at 4:58:34 pm
This is primarily for HD footage, captured in the same codec, such as ProRes. If that is your situation, use it.
Dave LaRonde
Laura Rossi
on Oct 7, 2009 at 5:37:56 pm
yes Dave I'm working with hd footage, the conform seems to be very easy to use, I hope there will be not any hidden complication.
thank you.
Laura Rossi
Re: troble with 25 ftg material in a 24ftg project ;)
on Oct 11, 2009 at 5:14:15 pm
Hi Dave, Im sorry to bother you...
I've used compressor but nothing changes, mmm maybe i'm missing something, is there any other way to do this?
thank you!
Laura
