FCP to Beta SP no picture
Heather Trawick
on Oct 6, 2009 at 8:16:38 pm
I'm trying to output from FCP to Beta Sp through a patchbay, and am having problems. The Audio records on to tape, but no picture. I'm using a Sony PVW 2800, through a blackmagic card using the apple pro ress 422 codec. Any leads?
Heather
Final Cut Studio 2 (6.03) Decklink Extreme SDI/Component I/O
G-Film Effects
Mark Spano
Re: FCP to Beta SP no picture
on Oct 6, 2009 at 9:05:27 pm
I would check if your card is outputting on component AND if your deck is set to component input. The deck may have an external switch to go between composite, dub, and component.
Petteri Evilampi
on Oct 7, 2009 at 10:03:05 am
Check out this: go to ➔ FCP Audio/Video Settings ➔ A/V Devices ➔ Different Output for edit to Tape/Print to Video, and this one should NOT be tabbed!
Ken Jones
on Oct 7, 2009 at 4:18:12 pm
After making sure that your patching is correct, check here:
Apple Menu/System Preferences/Blackmagic/Settings Tab/Set Output (needs to be on Y, R-Y, B-Y)
