Optimal Digital Record Drive for MultiCamera Workflow
Christopher Targia
on Oct 5, 2009 at 1:50:17 pm
Here's the story, we will be doing a shot with 2 studio config cameras that will be running through a switcher, and we also will have a Panosonic HPX200 camera running around, and I need all of these to be digitally ingested onto a Mac with Final Cut, Any switcher we will be using should have multiple output options; HD analog component/SDI -digital, etc. The Digital Record drive should be able to intake from the switcher as well as P2, what would the best hardware for this scenario, it will only be rented so price isn't too much of a worry, I have done some research and
Panosonic AJ-HRW10
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId...
or
Panosonic AG-HPG20
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?display...
should work, but I do not have any experience with this kind of hardware so I wanted some of your guys' opinions.
thanks in advance.
Steve Eisen
Re: Optimal Digital Record Drive for MultiCamera Workflow
on Oct 5, 2009 at 2:39:25 pm
I would recommend the HPG-20, AJ-HPM200 or AJA's KiPro.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Christopher Targia
on Oct 5, 2009 at 2:43:40 pm
I had come across the AJA Ki Pro also, but can it input p2 cards?
Steve Eisen
on Oct 6, 2009 at 1:16:36 am
KiPro has all video connections except Composite. No input for P2 cards.
Take an output from your switcher to the unit and record to ProRes.
Personally I would iso the cameras and record your mix to the HPG-20 or other device you choose.
Steve Eisen
Board of Directors
