Diagonal Scratch Removal Filter?
John Wise
on Oct 4, 2009 at 7:55:42 pm
Hi, all!
I'm re-cutting an old feature film that regrettably contains some diagonal scratches (a.k.a. "rain"). The scratches are generally only one frame in duration.
Does anyone know of any FCP scratch removal filters/plug-ins that can be adjusted to angles other than vertical?
Many thanks!
Arnie Schlissel
Re: Diagonal Scratch Removal Filter?
on Oct 5, 2009 at 4:28:48 am
If you have Photoshop Extended, you can paint out the scratches there. Otherwise, I'd use Shake.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
