QuickTime 720p with 5.1 sound
Karlis Jaunzems
on Oct 4, 2009 at 1:07:55 am
Hi Everyone,
I have this problem. I have Apple ProRes HQ 720p QT file with 5.1 sound. What I need to do is, I need to compress it with h.264 compression so it would fit into DVD9 disk but to keep the 5.1 sound in it. Problem right now is that Compressor 3.5 does not allow me to do it. It does, however, the compression beautifully but does not keep the 5.1 sound. Is it possible somehow trick the Compressor 3.5 to keep it?
Running Mac Pro Octo-Core, Leo 10.5.8, Final Cut Studio 3, if that matters.
Thanks in advance!
Best Regards,
Karlis Jaunzems
Michael Gissing
Re: QuickTime 720p with 5.1 sound
on Oct 4, 2009 at 2:08:31 am
The sound should be processed separately into an ac3 file.
David Roth Weiss
on Oct 4, 2009 at 2:26:18 am
[Karlis Jaunzems] "What I need to do is, I need to compress it with h.264 compression so it would fit into DVD9 disk but to keep the 5.1 sound in it."
For what intended goal?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Karlis Jaunzems
on Oct 4, 2009 at 2:39:43 am
Basically the project itself is finished. It was a concert DVD with both 2.0 and 5.1 sound tracks. I just want to do for the team a 720p version of the concert as a mov file to give it to them. That is the reason I'm asking. If there is not workaround I guess I'll have to suffer with it and give it to them as 720p mov with Stereo sound.
Best Regards,
Karlis Jaunzems
Arnie Schlissel
on Oct 4, 2009 at 2:44:14 am
[Karlis Jaunzems] "I need to compress it with h.264 compression so it would fit into DVD9 disk but to keep the 5.1 sound in it"
If you're trying to make a standard DVD, then h.264 is not compatible. You need to use MPEG2.
http://www.dvddemystified.com/dvdfaq.html#2.14
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Karlis Jaunzems
on Oct 4, 2009 at 3:04:45 am
sorry. i guess i didn't explain correctly. i'm not trying to make a dvd. i'm trying to make a mov file which would fit in a dvd9 data disk (~7.3gb big) hopefully with 5.1 sound. It's not meant for any type of stationary players, just for computer to play in quicktime player.
thus far i've managed to create only h.264 mov file with stereo sound, but i'd like to have it with 5.1 sound since we put so much hassle in it. is there a possibility through either compressor 3.5 or qt conversion to make h.264 with 5.1 sound?
Best Regards,
Karlis Jaunzems
Mikey Bouchereau
on Oct 4, 2009 at 4:02:28 am
Here ya go I just made you a compressor Droplet, I have FCS 3 so I am not sure if it will work with early versions. These are the specs for the droplet
Name: 5.1 Surround 720 h264
Description: Do not use on aspects other than 16x9 or it will will cause picture distortion. This will mimic the 720p Apple Trailer.
File Extension: mov
Estimated size: 2.69 GB/hour of source
Audio Encoder
AAC, 5.1 (C L R Ls Rs LFE), 48.000 kHz
Video Encoder
Format: QT
Width: 1280
Height: 720
Pixel aspect ratio: Square
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls On:
Retiming: (Better) Motion Compensated
Resize Filter: Statistical Prediction
Deinterlace Filter: Better (Motion Adaptive)
Adaptive Details: On
Antialias: 0
Detail Level: 0
Field Output: Progressive
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 75
Min. Spatial quality: 50
Key frame interval: 45
Temporal quality: 50
Min. temporal quality: 50
Average data rate: 6.418 (Mbps)
Fast Start: on
Compressed header
requires QuickTime 3 Minimum
310_5.1surround720h264.app.zip
Mikey B!
Follow Me On Twitter!
Karlis Jaunzems
on Oct 4, 2009 at 4:31:33 am
Awesome! Thanks a billion!
Best Regards,
Karlis Jaunzems
