Motion tracking
paula Stein
Motion tracking
on Oct 3, 2009 at 8:53:16 pm
I need to create a sparkle effect on a tooth of someone talking, a clip that runs for 5 seconds.
I am using In the library in Motion, under generators - STAR, placed it on the timeline of the clip.
My question is what is the best way to track the sparkle effect throughout the clip keeping it over the
tooth as the image moves?
Thank you for your help!
"A journey of a thousand miles must begin with a single step." ~Lao Tzu
david bogie
Re: Motion tracking
on Oct 4, 2009 at 3:09:30 pm
You are going to be using Motion. You will start in the online manual under "motion tracking" and you will need lots of time to work on it.
If you did not shoot the scene with motion tracking in mind, you will be entering many manual keyframes. This is advanced work requiring patience and lots of failed attempts.
bogiesan
