AVCHD to SD Workflow?
Adam Schoales
on Sep 26, 2009 at 5:11:24 am
So I posted about how I have HD and SD footage for a multiclip sequence and I need to try and mix the two together which means either Upscaling SD or Downscaling HD. I figured the second option makes more sense since the footage will likely be going out to DVD.
As such I was curious as to what the workflow would be. I figure I should use Compressor but wasn't sure what settings I should use (specifically the frame size to ensure the footage comes out 16:9).
Also, I've brought the AVCHD footage in as Pro Res (Proxy), but wasn't sure if I should bring it in at the full pro-res then convert to SD or if the Proxy would be good enough?
Any help would be greatly appreciated!
