50Hz Lighting in 1080i60 Video
David Peralta
on Sep 25, 2009 at 9:15:47 pm
Hi All,
We are going through some edited pieces that we did in south africa and we acquired video via HV20 at 1080i60 and using a EX-1 @ 1080i60. and noticed that there seems to be some sort of flicker which I believe is coming from the light bulb @ 50 Hz.My Timeline is set at Pro Res - 1080i60 and the piece will be downconverted to SD for playout on our show. Is there a way to reduce the flickering? Filters? or do we just deal and move on?
Thanks for the advise
-dave
hmm... I wonder what this button does...
Dave LaRonde
Re: 50Hz Lighting in 1080i60 Video
on Sep 25, 2009 at 9:36:53 pm
About a week ago, there was a thread from a guy who shot a wedding. A ceiling fan put a flicker into the overhead lights: very annoying. Somebody mentioned a plugin that could very well do the trick.
It might be work searching for it.
Dave LaRonde
Sr. Promotion Producer
Arnie Schlissel
on Sep 25, 2009 at 9:42:50 pm
Furnace from The Foundry, or I think someone mentioned Sapphire.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Phil Balsdon
on Sep 25, 2009 at 10:46:38 pm
In hindsight (unfortunately) you can avoid this problem by shooting with a shutter speed of 1/100th second (or 1/50th if you can set it in the camera).
Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
http://www.steadi-onfilms.com.au/
Kristin Leys
on Sep 27, 2009 at 7:55:05 pm
I replied to the wedding video post suggesting GenArts Sapphire plugins.
I used the flicker filters to solve a similar issue with fluorescent lights on PAL SD footage.
The results weren't perfect. But with some effort I restored several 'critical' scenes.
This was for a documentary where reshooting wasn't an option.
You can try the demo version to see if the filters will work for you.
David Peralta
on Sep 29, 2009 at 1:11:33 am
thanks all, will check it out
