What is the best codec in camstudio to use when working in Final Cut
Wesley Summers
on Sep 25, 2009 at 7:11:46 pm
Hello I am editing some how to videos that are 2-3 hrs long and captured using camstudio on a pc. Currently it is being captured using a divx codec and the files are .avi. They look good, but when I bring the files in to work on in fcp it takes an ungodly amount of time to render. I found a codec called Ensharpen that is supposed to capture in a quicktime format, I tried downloading a trail but for whatever reason it isn\'t showing up in the codec video options menu. I was wondering if anyone else has had experience working with screen captured files using camstudio and what codec or setting you would recommend.
OR also thought of trying a scan converter to svideo or RCA, and then record it with a camera.
Any help is greatly appreciated, b/c at this rate I might be through rendering by Christmas
-Wes
Rafael Amador
Re: What is the best codec in camstudio to use when working in Final Cut
on Sep 26, 2009 at 9:38:16 am
Hi Wesley,
I have never worked with that kind of stuff, but I think that capturing to any QT codec should be better.
I think that to play the "Ensharper" codec you need a reader.
Rafael
http://www.nagavideo.com
Wesley Summers
on Sep 26, 2009 at 1:37:19 pm
Isn't the "reader" camstudio or is a reader a seperate program of some kind?
Wes
Rafael Amador
on Sep 27, 2009 at 3:13:07 am
Hi Wesley,
You can download the "Free Decoder" from this page:
http://www.techsmith.com/codecs/ensharpen/
Rafael
Rafael Amador
Re:Sorry double post
on Sep 26, 2009 at 9:42:08 am
Hi Wesley,
Rafael
