Problem with different formats on same sequence
Gino Marín
on Sep 25, 2009 at 4:13:29 pm
Hello!
Well, this is my first question on the cow's forum, so i really thank your help.
Well, the problem is this:
I have a sequence on HD, and I have 2 clips on it, one its on HD and the other its on standard, so both have different size, differente frame rate and different format. So, when I do that, and I play it for make a master on betacam, the video run at different time than the audio, so i cannot make a master on that computer. How do I fix that?
Thanks a lot for your help! :D
Shane Ross
Re: Problem with different formats on same sequence
on Sep 25, 2009 at 4:30:30 pm
Convert one format to the other. Since you are going to Betacam, then convert the HD to be SD. And make sure to convert to the frame rate to 29.97 (NTSC) or 25 (PAL)...depending on where you are located.
Shane
John Fishback
on Sep 27, 2009 at 8:01:18 pm
The only things you really shouldn't mix on an FCP timeline are clips with different timebases.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
