Installing Content from disk images
Brandon Verderber
on Sep 25, 2009 at 3:08:31 pm
I have read through many forums and still have not found a solution to this question. I have installed Final Cut Studio 3 on my machine through disk images, but the install keeps crashing on the motion content. I have tried installing the content separately and I still got an error message at the same spot. It's happening at the end of the install when that disk is done whatever it is.
Rafael Amador
Re: Installing Content from disk images
on Sep 25, 2009 at 4:07:14 pm
Hi Brandon,
The image may be corrupted.
Try to open it up.
Let the Disc Utility make the "check sum".
rafael
http://www.nagavideo.com
