Glitch in dissolves
Rory Keenan
Glitch in dissolves
on Sep 25, 2009 at 7:44:05 am
I'm doing a piece that has a series of stills (most are resized & have slow zooms)
When I dissolve between two still frames there is a glitch after the last frame of the dissolve.
Has any one else had this problem?
It looks as though the frames within the dissolve are slightly blurred . . . . then they get suddenly sharper on the first frame after the dissolve has finished
I've also tried putting the stills on two seprate video tracks and fading one up and the other down simultaniously and I still have the same problem.
This happens even if everything is rendered
Neil Sadwelkar
Re: Glitch in dissolves
on Sep 25, 2009 at 4:42:34 pm
What's the sequence setting? And stills format?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Rory Keenan
on Sep 25, 2009 at 6:23:00 pm
The stills are jpegs
I'm not sure of the sequence setting I'll check this afternoon. . . . (someone else did the original sequence, I was just asked to change a few stills on a last minute basis)
cowcowcowcowcow
David Roth Weiss
on Sep 25, 2009 at 5:04:06 pm
[Rory Keenan] "This happens even if everything is rendered"
Go to Sequence>>Render All and make certain that "Full" is checked, then re-render.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
