Apple Keynote Presentation Style Editing
Blue Melnick
on Sep 24, 2009 at 11:36:16 am
Morning,
I'm in the process of editing a stage presentation from a speaker who used powerpoints for his slides. I recorded the slides using Screenflow, and then exported that video to the HDV format so I could use it in a multiclip edit with the other two cameras used.
I'd like to use some of the transitions and effects that Apple uses when they post a video of their keynote presentations (video image of Steve on the left with the presentation on a slight angle with a mirror, plus some straight up PIP, and then of course sometimes just full screen ppt).
While I can do this manually in each case, I'm wondering if there is a way to "template" this so that when there is a ppt presentation on screen, I can select one of the three options (full screen, pip, angle pip).
Any thoughts :)
Thanks all!!
Blue
Michael Gissing
Re: Apple Keynote Presentation Style Editing
on Sep 24, 2009 at 11:41:59 am
Having created any one of those, you can copy paste attributes like distort, crop, etc. If you want to put an example of each of the three somewhere accessible (like in a new sequence) then you can go to them to copy quickly.
