FX Script Error
Sam Lesante Jr.
FX Script Error
on Sep 23, 2009 at 3:45:48 pm
So i am trying to render my project out.
I was able to render out a couple clips but half way through a window comes up and says "FX Script Error - Variable is Read Only"
All the clips are read and write so i don't know what the problem is.
Any suggestions?
TIA
Sam
Arnie Schlissel
Re: FX Script Error
on Sep 24, 2009 at 3:09:24 am
There's a problem with one of your plugins. You'll have to figure out which filter on which clip by turning them off one at a time until the sequence exports.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
wayne kurtz
Re: FX Script Error
on Jul 2, 2013 at 5:09:15 pm
I also have same issue. Probably one of my editors used a plug in which is not loaded onto my machine.
It is large project and very hard to find it to remove. What if I leave it in the timeline? Will it play without a transition there or will a "not on file" or something message pop up when reachign that point?
I sent project to compressor and there was no warning of "offline media"
