Relinking 2K footage to sequence in fcp with 4k footage (RED)
chris williams
on Sep 18, 2009 at 7:35:36 pm
So I am editing a music video shot on the red camera in FCP. I (stupidly) ingested the footage at 4k and started editing. now I am in the middle of an edit, and am worried that things will start to screw up due to working with such a large media database. I have converted the filed to 2K using redrushes. My question is how do I replace the 4k files with the 2k files and continue editing where I left off, cause after all, the files have identical names.
Neil Sadwelkar
Re: Relinking 2K footage to sequence in fcp with 4k footage (RED)
on Sep 19, 2009 at 5:48:50 am
There is probably some way one could achieve this with XMLs or EDLs. But you know what. Even if this could be automated, you will still need to make reference video and compare that the re-conform worked.
My suggestion is to manually replace the cuts with the new Quicktime 2k movies. It would be faster if you have less than 50 cuts to replace.
Since the names and timecodea are the same, it won't take as long as you'd imagine.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Michael Gossen
on Sep 19, 2009 at 5:16:15 pm
Maybe Crimson would help. http://www.crimsonworkflow.com/home.htm
Michael Gossen
Helium Digital Media
