smooth cam - fcp 7 ugrade issue?
j. clive jordan
on Sep 17, 2009 at 4:04:18 pm
Hello, any suggested are appreciated:
I have lots of experience with 'smooth cam' and have used it very successfully over the years, but I just upgraded to FCP 7 and the output looks terrible - extremely shakey video that looked fine in fcp 6. It looks like it has field order issues.
I tried re-rendering the mtdf file - that didn't work
I tried changing field order - that didn't work
I tried de-interlace - that didn't work.
any suggestions?
j clive jordan
http://www.kitesites.com
check out the latest episode!
Kevin Hamm
Re: smooth cam - fcp 7 ugrade issue?
on Sep 17, 2009 at 7:23:17 pm
Do you have any speed changes on the clips? We had this problem with a clip and we just removed the speed changes, re-rendered and it was fine, then added the speed changes back and it worked fine.
The other option is to delete the analysis file and let it re-analyze the clip, but that would be a nightmare.
Kevin Hamm
Video, Web, Print and coloring books.
j. clive jordan
on Sep 17, 2009 at 11:21:54 pm
no speed changes,, I guess I'm the only one with this problem. I also re-analyzed the clip - didn't work..
j clive jordan
andres garcia
on Sep 23, 2009 at 3:40:58 pm
Hi I am having the same problem...somone there... that could help us?
Andres
Andres Garcia
http://www.covisual.com
Wolfgang Medicus
on Oct 1, 2009 at 10:42:52 am
I'm also having this problem. Cutting ProRes 4:2:2 HQ Progressiv Material. I tried several export codecs... but hopeless.
Maybe a problem with Quicktime ?
I have Player 10.0 installed.
Someone any idea ?
Wolfgang Medicus
on Oct 5, 2009 at 8:14:22 am
Hello again,
here is a workflow to fix the problem:
- Export the Clips (before smooth cam)
- Reimport it in the timeline
- Smooth Cam
I used MPEG Streamclip to get the ProRes Files from a JVC Everio Camera (TOD-Files). It seams that Final Cut isn't 100% compatibel with this.
