XDCAM rendered in AE produces dropped frames
Dave Beaty
on Sep 17, 2009 at 11:10:51 am
I am cutting a show in XDCAM 1080i 35Mb VBR codec. Everything looks great from the the show camera masters. I rendered some graphics in After Effects with the same codec settings. When I play these graphics, I get dropped frames after about 4-5 secs on any of the rendered clips.
My system uses a Fusion SATA RAID 0 with about 200MB read/write. 8 Core Mac. No other HD codecs have given me this problem. I am suspecting it may be AE, because if I render to Pro Res 422 and then let FCPro render the clips in the XDCAM sequence, they play fine.
Dave Beaty
Dreamtime Entertainment
1625 SE 46th St
Cape Coral FL 33904
John Fishback
Re: XDCAM rendered in AE produces dropped frames
on Sep 17, 2009 at 2:32:57 pm
Is your AFX timebase correctly matched to your FCP timebase? What are they?
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
© 2018 All Rights Reserved
