FCP 6 compatibility with DV/Mini DV Decks
Robert Decker
on Sep 15, 2009 at 9:19:31 pm
Question...I have FCP 6 on my IMAC. Im looking to purchase a MiniDV/DV deck to log and capture into FCP via firewire. Any suggestions on compatible decks?
I found a Sony DSR 30 and a JVC BR-DV600U for a reasonable price. Anyone know if those two are compatible with FCP 6?
Shane Ross
Re: FCP 6 compatibility with DV/Mini DV Decks
on Sep 15, 2009 at 9:29:49 pm
They are.
Shane
Bret Williams
on Sep 16, 2009 at 2:22:55 pm
Well the 30 is pretty useless. Doesn\'t support e to e which means if you want to bring in some other format through the deck,you\'d have to record it to tape first.
The 600 has component in/out and maybe xlrs if I remember right, but only does miniDv, not DVCam or DVCPro.
Both are pretty ancient. 10 years old or so.
Arnie Schlissel
on Sep 16, 2009 at 2:19:58 am
[Robert Decker] "I found a Sony DSR 30 and a JVC BR-DV600U for a reasonable price."
Those are both SD only decks. I've heard that this HD thing may take off someday.
It's the 21st century. Maybe you should be looking at a Sony HDV deck. It will play back miniDV tapes, but it will also play back Sony & Cannon HDV tapes. That will open up more possibilities for you right now than buying a used SD onlu miniDV deck.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Nick Price
on Sep 16, 2009 at 1:53:44 pm
Arnie is right, But almost any camera with a firewire out port (also called iLink or IEEE1394) will work with FCP. I use an old sony consumer handycam sometimes.
nick
